Activity Forums Apple Final Cut Pro Legacy Rock solid change lists in FCP
  • Rock solid change lists in FCP
    Posted by George Mandl on December 30, 2010 at 1:59 am
    Hello There,
    I’ve just run into a guy at a post-sound facility who gave me the old “Avid is so much better than FCP” speech. This was specifically in connection with change lists. He said that FCP-generated change lists are often full of errors. I asked what he meant, and he said that they often give bad timecode ins and outs. It seemed odd to me, but I wanted to ask the cow community about this. Do you deal with change lists from FCP for sound? If so, what settings are you using, and are they working well for your sound house?
    Here is an example of one that I made. Do you see anything wrong with it, inherently (aside from the weird formatting that happens when its pasted in this window)?
    George
    Cinema Tools change list.
    This list was generated by Cinema Tools version 4.5.1
    on Dec 27, 2010 at 9:46:32 AM
    The original sequence is “Reel 2_Sc 22-42 12.16.10 TF”.
    The new sequence is Reel 2_v1.1 to SND 122710 QTREF.
    The original video track is 1.
    The new video track is “1”.
    The settings:
    Do not include a change pull list.
    Do not include a change discard list.
    Show only changes.
    Do not combine deletions.
    Show feet and frames.
    Show clip name.
    Show key numbers.
    The statistics:
    original length = 1474+01
    new length = 1478+07
    174 shots unchanged for 1308+13
    10 gaps unchanged for 0159+11
    1 shots added for 0007+00
    1 gaps added for 0002+02
    1 shots deleted for -0002+02
    1 adds for 0000+13
    3 trims for -0003+07
    0 moves
    +0004+06 net difference
    At This For This Total
    Footage Do This Length First/Last Key Clip Name Change
    _ 1. 1402+10 Trim Tail – 0000+05 41C_02c – 0000+05
    1402+14
    _ 2. 1402+10 Insert Shot + 0007+00 41E_02a + 0006+11
    1409+09
    _ 3. 1409+10 Trim Head – 0002+05 41_06a + 0004+06
    1411+14
    _ 4. 1413+05 Trim Head – 0000+13 41A_02a + 0003+09
    1414+01
    _ 5. 1413+07 Lengthen Tail + 0000+13 41A_02a + 0004+06
    1414+03
    _ 6. 1436+01 Delete Shot – 0002+02 R43B_02a + 0002+04
    1438+02
    _ 7. 1436+01 Insert Leader + 0002+02 Leader + 0004+06
    1438+02
    George Mandl replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
