Activity › Forums › Adobe After Effects › rock n rolla movie style intro
Posted by Eddy Lizi on April 9, 2013 at 1:00 amhello,
i am surprised i could not find any info about it online
what i want to do is freeze time on the video cut the person add animation and 3d layers and continue to the next person similar to rocknrola movie intro but i want to make the effect from the original footageHOW I DO THAT?
i thing there is got to a tutorial for thatthanks guys
Eddy Lizi replied 13 years, 5 months ago 4 Members · 6 Replies -
Paul Stevenson
April 9, 2013 at 10:05 amI have never seen the film so can you find an example online?
But going from your explanation it sounds like you want to time remap your footage to stop and start where you want, then use another layer(s) to do your fancy bits. I can’t comment on how you might go about that without seeing the intro.
John Cuevas
April 9, 2013 at 11:59 amhttps://www.youtube.com/watch?v=SYHw_h1YdkA
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb.Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Paul Stevenson
April 9, 2013 at 12:16 pmGood god man! How long have you got? And how much like Rock N Rolla do you want it?
In brief it’s built up of: Vector/vector like artwork (lots of it), 3D layers, particle effects, wipes, masks and colouring etc. The animation could be mainly taken care of within AE with the camera or by moving the layers in simple ways.
It’s not necessarily complicated per se, but it’s going to be time consuming.
Eddy Lizi
April 9, 2013 at 3:57 pmthank you for your reply’s guys
paul – i have a few days and my problem is that i am working on 2 more projects thats why i was looking for a tutorial or something so it will go faster
what i want to do is not the same 100% like rocknrolla but similar
i want to create it from video and to add the effects only on one frame and than continue the video from the same point that i stopped
thx -
Walter Soyka
April 9, 2013 at 4:39 pm[eddy lizi] “i want to create it from video and to add the effects only on one frame and than continue the video from the same point that i stopped”
Go to the frame you want to freeze on, then split the layer [link]. Advance one frame, then split the layer again. You now have three layers — one before the freeze, one single frame for the freeze, then everything after the freeze.
Select the single-frame layer, then freeze it (Layer > Time > Freeze Frame). You can now extend it however long you like and slide the rest of the layers back in time.
You could also do this with time remapping [link].
Walter Soyka
