Activity › Forums › Maxon Cinema 4D › Robot mouth animation synced to a voice track
  • Robot mouth animation synced to a voice track
    Posted by Ron Moore on October 17, 2020 at 2:56 am
    I’m needing to do some simple animation varying the Y position of a robot’s mouth shape to coincide with the spoken word (no music) and have tried several options but no luck so far. Tried the MoGraph Sound Effector and it does the trick, but apparently only operates on MoText objects. Also tried GSG’s Signal plugin, but I think it only responds to a music input, but can vary anything animatable based on the BPM. At this moment all I’m able to figure out is to simply put a Vibrate tag on the mouth object and let it go about its business randomly moving about the Y axis, close but hardly a “lip-sync”. Any suggestions?
    Andy Kiernan replied 5 years, 11 months ago 2 Members · 3 Replies
  • Andy Kiernan
    October 21, 2020 at 1:39 pm
    I may be wrong but if you put the mouth geo into a fracture object, left at ‘straight’, then apply the sound effector to the fracture object, you should get what you need.
  • Ron Moore
    October 21, 2020 at 7:00 pm
    Yep, you got it. So often, like pre-comping a layer in After Effects, just applying the dependable Fracture Object in C4D makes it all better. I ended up using Pose Morphs, but would have rather not had to deform the geometry, so this is the preferred method, and simpler! Thanks.
  • Andy Kiernan
    October 23, 2020 at 10:56 am
    Ha yeah thats how i think about it too, like a precomp. If i can get stuff into the mograph module, i will!
