Activity Forums Adobe After Effects Robin Hood like Painting Effect in After Effects?
  • Robin Hood like Painting Effect in After Effects?
    Posted by Max Amann on June 21, 2011 at 11:36 am
    Dear Creative Cow-Team!
    I have a question regarding the possible re-creation of an effect (doesn’t have to be the exact same result, just the same style). Any hint or help would be greatly appreciated.
    A customer of ours wants an intro similar to the Robin Hood Credit Animation (Painted Look over real-life footage)
    Here’s a sample:
    https://www.youtube.com/watch?v=GvrnLlqQca4
    I tried to use the cartooner and brush strokes effect but none of them worked out the way I wanted.
    The brush strokes effect is cool, but it makes the footage too turbulent. Cartooner makes the footage look too cheesy.
    I’m absolutely helpless on this one!
    Your support is greatly appreciated.
    Best regards
    Max
    Bobby Cuffe replied 11 years, 8 months ago 4 Members · 4 Replies
  • Tudor “ted” jelescu
    June 21, 2011 at 1:21 pm
    Toonit from Red Giant may help you with the look you want, although I think the title sequence you gave as an example involved a lot more than just a plugin.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Max Amann
    June 21, 2011 at 1:26 pm
    Hi Tudor!
    Thanks for the quick response.
    You are probably right. I guess they painted frame by frame and did not use a plugin.
    As we neither have the time nor the budget to do this I wanted to know if there’s a way to create a similar result.
    Thank you for your tip! I’ll have a look at Toonit
    Your help is greatly appreciated
    Best regards
    Max
  • Alejandro Sorin
    January 3, 2013 at 11:12 pm
    “Paint” included in Tinderbox 3 plugin pack used to do something similar. https://vimeo.com/2380159 . Best wishes
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Bobby Cuffe
    January 11, 2015 at 6:11 pm
    Hi
    https://vimeo.com/28067869
    https://vimeo.com/70262275
