Activity › Forums › Adobe After Effects › roaming over time
  • roaming over time
    Posted by Maryanne Hamill on June 20, 2005 at 7:34 pm
    Okay this one has always baffled me. I have a picture that is larger than my 720×480 comp. All I want to do it move from the top, down the picture, over to a new point & up again. Basically keyframe to keyframe. Sounds simple. But in between my key frames my picture drifts. It ends up in the correct position but AF doesn’t calcuates a straight line. In my wire frame path I can see the drift but there are no keyframes there to create an arch like it’s doing. I know it’s something simple but I don’t know what that might be. What am I doing wrong?-Maryanne
    Maryanne Hamill replied 21 years, 3 months ago 2 Members · 2 Replies
  • Peter Stenhouse
    June 20, 2005 at 8:41 pm
    hey there. In order to change this you need to either cntrl click (apple) or right mouse button(PC) the keframe in the timeline and go to Keyframe Interpolation mode and change it to Linear, rather than Auto Bezier. Auto Bezier is kinda like an ease in ease out type thing.
    In your Prefrences you can set keyframes to have a Linear Interpolation as default.
    Hope this helps
    Peter
  • Maryanne Hamill
    June 21, 2005 at 1:26 pm
    Sure enough that worked. I can’t believe all this time I didn’t know that. Thanks Peter.
    Maryanne
