Activity Forums Maxon Cinema 4D Road signals with names
  • Jeremy Allen
    June 14, 2012 at 4:51 pm
    This should be a breeze with a locked tripod shot. And you don’t even need C4D to do it. I would put the shot in After Effects, create your text, make it a 3D layer. Then rotate and scale as needed, and maybe play with some overlay modes or slight masking (cracks, grunge) to make it look more real.
    Also, don’t make the letters pure white. Try to make them match the white balance of the scene. Hope this helps, and good luck!
    8core MacPro, 3.0 GHZ, 18GB RAM, OSX 10.5.8
    C4D 12
    AE CS5 (10.0.2.4)
    FCP 7.0.3
    QT 7.6.4
  • Randy Johnson
    June 15, 2012 at 6:42 am
  • Julius Smith
    June 15, 2012 at 2:54 pm
    thanks..looks like I have to register to get the free tutorial….does this work with video as well?
