Activity Forums Adobe After Effects RLA problem
  • RLA problem
    Posted by Ondrej Mencl on October 8, 2007 at 9:43 am
    Hi. I render sequence in RLA format with information Material ID and i open it in AE than i would like to change or modify the channel Material ID i relized that there is no antialiasing on the channel, so basicly it is not useful becouse i see all the “not antialiased” edges. The picture its self is antialiased but all the channels stored in RLA format they are not? Is it correct? What im doing wrong? Thanx very much for advice.
    Ondrej
    Jerzy Drozda jr replied 18 years, 11 months ago 2 Members · 1 Reply
  • Jerzy Drozda jr
    October 9, 2007 at 4:02 pm
    Yup, that’s rather normal thing to happen. The way it looks really depends on implementation of the “encoding to” and “decoding from” algorithm.
    Anyway… if you’re experiencing this you should render the image as a PNG sequence for example, then shut everthing that slows down the render off, like lights, caustics, textures, blahblahblah, and render doubble sized RLA (i prefere RPF).
    That should do the trick.
    maltaannon.com – Free After Effects Video Tutorials and more
