Activity › Forums › Adobe After Effects › Rising numbers….
  • Rising numbers….
    Posted by Jamie Worsfold on September 16, 2005 at 4:28 pm
    Hi
    Quick idea to challenge some of you guys:
    I’m editing a TV programme which has a powerboat speed run in it. What I need to do is have the speed rising from the start of the run until the end, but not at a consistent rate. ie It needs to go up to a certain point, maybe drop off a bit, then rise a bit more etc….
    I can’t find a plugin that does this. And as the speed run is over about 30 secs, it will be a bit laborious to go through every single frame and change the numbers. But I’m thinking this may be the only way….!
    If any of you guys out there have any ideas for a cunning way round this, then your thoughts would be greatly appreciated. Thanks! 🙂
    Jamie Worsfold replied 21 years ago 2 Members · 2 Replies
  • Steve Roberts
    September 16, 2005 at 5:04 pm
    Have you tried Time Remapping?
  • Jamie Worsfold
    September 19, 2005 at 10:29 am
    Ahaaaaa! That may indeed do the trick… hadn’t thought of that. Thanks!
