Activity Forums Adobe After Effects Ripple from a water drop
  • Ripple from a water drop
    Posted by Faza Lutfi on February 18, 2006 at 6:28 pm
    Hello all..
    I am trying to create an effect of a water droplet hitting a pool of water.. I have tried the ripple effect in AE but the thing is it keeps on generating the wave.. i have tried keyframing but none of the sliders seem to create a realistc looking ripple…
    What i would like to happen is a when the water drop hits the layer.. it creates a few rings which travels outwards.. the ripple should die down from the center outwards (like in real ripples).. if there is anyway i can do this with a plugin or with some other program please let me know.. appreciate reading the post.. thanks
    Sam Moulton replied 20 years, 7 months ago 4 Members · 6 Replies
  • Mike Clasby
    February 18, 2006 at 7:05 pm
    Caustics and Displacement, here’s a tut:
    Articles: Sort By Author: Jim Tierney
    Droping into caustics
    https://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=2&page=https://www.creativecow.net/articles/tierney_jim/caustics/index.html
    Also click on Aharon Rabinowitz’s head above and see his 2 tut on displacement maps (a 3rd to come),
    Good stuff.
  • Faza Lutfi
    February 18, 2006 at 7:45 pm
    thanks for the quick reply…
    I have tried this tut… it works great.. however I am not just doing one drop of water.. I should have explained this in the first post..
    Basically.. its several drops hitting a water surface.. it cant be just a rain plugin as i need to customize the location of where it is hitting.. its about 50 drops.. The thing with wave wolrd is its so processor intensive its impossible to do this many… i tried displacement mapping with a video file of a drop of water.. but than again i cant customize the location with this either..
    any other thoughts would be much appreciated…
    thanks
  • Mike Clasby
    February 18, 2006 at 8:16 pm
    Aha, I think you want Simulate > CC Drizzle, turn the drip rate way down (the default is a boiling water effect) and tweak the other parameters to get scattered raindrop ripples. As far as confining to an area, masking is all I can think of. You might have to trial-and-error tweak until you come across a pattern you like.
  • Faza Lutfi
    February 18, 2006 at 9:39 pm
    tried everything with drizzle..
    is there no plugin that just does a single ripple.. spreads and die…
    even in another program??
  • Graham Quince
    February 19, 2006 at 1:52 pm
    Have you tired Radio waves.
    You can tweak the frequency to produce a single circular wave with faded back end. Pre-comp this effect on a solid and use it as your displacement map for you ripple.
    Hope the helps
    Graham
    https://www.qcit.co.uk – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Sam Moulton
    February 23, 2006 at 2:37 am
    did you try searching for ripple and include the archives. There are a bunch of ways to do what you want. I got a huge list that I’m exploring right now.
