Activity › Forums › Maxon Cinema 4D › Ripple effect help!
Ripple effect help!
Posted by Julia K on October 26, 2006 at 3:29 pmWhat is a best way to create the drop and ripple effect in Cinema4d, I’m fairly new to the program and need to finish a project by tonight…
Please, help!!!!Thank you!!!!
Julia K replied 19 years, 11 months ago 2 Members · 4 Replies -
Mylenium
October 26, 2006 at 4:03 pmUse the formula deformer on a plane. The default formula will create exactly what you need – a concentric ripple. Alternatively use the Ripple shader on your material.
Mylenium
[Pour Myl
Julia K
October 26, 2006 at 5:25 pmI did both, created an animated bump map that worked well, but with the formula how do i start the ripple and have it die off before it reaches the end of the plane?
Mylenium
October 27, 2006 at 8:03 amYou’d need to add a multiplier to the sinus along the X and Z direction based on distance. That’s probably a bit too complex for what you need to do so it’s probably best to stick with the materila approach. ;O)
Mylenium
[Pour Myl
Julia K
October 31, 2006 at 7:42 pmI’d like to learn how to do that, if you don’t mind explaining it to me, i would greatly appreciate it!
