Activity Forums VEGAS Pro Ripple edit question…
  • Ripple edit question…
    Posted by Matt Schwartz on December 19, 2013 at 11:40 pm
    Is it possible to post edit, ripple MULTIPLE selected tracks but NOT others? I have been playing around with this awhile do not see how to do this.
    Stephen Mann replied 12 years, 9 months ago 4 Members · 4 Replies
  • Graham Bernard
    December 20, 2013 at 2:21 am
    You can Select the “Select All Affected” but everything to the right of the Cursor will move. If, as you’ve most likely discovered, if you have Events that span the cursor position then they wouldn’t.
    Ripple Edit is a very fine tool. It just hasn’t had any further development since it appeared. You’re not the first User wanting more from it.
    Cheers
    Grazie
  • Stephen Mann
    December 20, 2013 at 3:31 am
    Put the events into a group.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Roger Bansemer
    December 20, 2013 at 1:29 pm
    I switch back between having ripple edit on and off so much I’ve added my own hot key for it which is the caps lock.
    Roger Bansemer – PaintingAndTravel.com
  • Stephen Mann
    December 20, 2013 at 4:33 pm
    I am just the opposite – I may use Ripple Edit once or twice during an entire edit session. Then curse because I forgot to turn it off.
    Steve Mann
    http://www.mmdv.com
