Activity Forums Adobe Premiere Pro Ripple delete suddenly unavailable?
  • Ripple delete suddenly unavailable?
    Posted by Stan Weiss on November 4, 2007 at 2:58 pm
    I am editing a project which has a huge number of imported stills…when editing in the timeline I like to right click on any un-needed frames and select ripple delete…it very conveniently moves everything over…however suddenly i find that the ripple delete is greyed out(unavailable)…
    any ideas as to why this is the case….and also if i delete the frame with the delete key and then use my mouse in the now empty space then again ripple delete is not available!
    Thanks for any info!!
    Stan
    元 素 replied 15 years, 11 months ago 4 Members · 4 Replies
  • Blast1
    November 4, 2007 at 7:00 pm
    Try clicking on the clip you want to ripple delete to select it, then do Alt-backspace and see if that works.
  • Aanarav Sareen
    November 4, 2007 at 11:45 pm
    Stan,
    Make sure that there is nothing on the other tracks while ripple-deleting. For example: You want to delete content between time = 8 and time = 10. Make sure that all tracks are empty.
    – Aanarav
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Blast1
    November 5, 2007 at 10:15 pm
    You can have stuff on other tracks above or below, but there are a bunch of instances where you can’t RD or don’t want to, particularly if the other tracks have spaces in them, usually you can’t RD if a track above or below has a cut or join in the same area as the segment you are trying to RD or if a cut or join is after in time on another track the segment you you are trying to perform a RD on, You can ripple delete if there is a space in another track within the segment you are RD, be aware a ripple delete with spaces on other tracks will cascade till a track joins somewhere, its best to put 2 or 3 tracks of video and play with it till you see what it does, ^Z can be a life saver.
  • 元 素 Create COW Profile Image
    元 素
    September 14, 2010 at 6:12 am
    Thanx for your answer,
    It’s helpful for me who lapsed into the same question.
