Activity › Forums › Adobe After Effects › Ripple Cut in After Effects
Posted by Martyn Morris on July 27, 2010 at 8:15 amHi there,
I have a lot of clips to remove from the timeline and was wondering if anyone knows how to perform a Ripple Cut in After Effects as you can in Final cut??.
Or if there are any scripts out there that would Ripple Cut??.
This would save me a great deal of time.
Thanks, Martyn
Martyn Morris replied 16 years, 1 month ago 2 Members · 6 Replies -
Todd Kopriva
July 27, 2010 at 10:08 amSee “Remove part of the duration of a layer”.
Found with this search.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Martyn Morris
July 27, 2010 at 10:34 amThanks for the response Todd.
I have tried the solutions from the link you have sent but did not work. I thought the Extract Work Area. The gap is closed by ripple deletion would be the solution but unfortunately it left a gap.
I’m using CS4 if that helps.
Thanks Martyn.
Todd Kopriva
July 27, 2010 at 11:06 amI just tried Edit > Extract Work Area, and it left no gap.
If this isn’t working for you, please provide an exact, step-by-step account of what you’re doing and what’s happening. Screenshots would help.
Martyn Morris
July 27, 2010 at 11:29 am -
Todd Kopriva
July 27, 2010 at 11:32 amAh. I see your problem. Read the instructions again. They instruct you to set a work area. The work area defines the duration (time span) that will be removed and then closed by ripple deletion.
Martyn Morris
July 27, 2010 at 11:38 amWow thanks Todd.
Thanks for sharing your time to go though this with me.
This should speed up my work.
Thanks, Martyn
