Activity › Forums › Adobe Premiere Pro › Ripping DVD to pro
  • Ripping DVD to pro
    Posted by Lynn French on July 21, 2013 at 2:01 pm
    I am ripping a home made DVD w/ tipard and importing it into porous, editing it sending it to encore and building a new DVD. The new DVD will not play in either DVD player I have.What am I missing. I have tipard set to porous and mpeg 2,
    Chris King replied 10 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Chris Tompkins
    July 21, 2013 at 6:47 pm
    Do you mean prores?
    Try Mpeg Stream clip – rips right to mpeg2.
    Chris
  • Lynn French
    July 21, 2013 at 7:01 pm
    My mistake” premiere pro”
    I’m ripping to mpeg 2 with tipard
  • Ryan Holmes
    July 22, 2013 at 1:21 am
    So you’re ripping a MPEG-2 (DVD) into MPEG-2 format to make a DVD? Am I missing something here?
    If you want to edit the video in Premiere it’s best to rip it into some sort of intermediate codec (DNxHD, Cineform, DV NTSC, etc), then edit, then export to Encore via Media Encoder (I’m not a huge fan of the Dynamic Link aspect as it can be a bit flaky sometimes, which may be your problem).
    You can try exporting your timeline out via Media Encoder as a MPEG-2 (use a preset) and import that standalone file into Encore.
    In the future: MPEG Streamclip does the same thing as Tipard except it’s free (for Mac or Windows).
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
  • Lynn French
    July 22, 2013 at 1:42 am
    Thanks, as you can tell I am not well versed in this whole arena. I will try your suggestions. I did rip the DVD into an avi file, edited it, and then sent it to encore, and the same thing happened. The DVD would not play.
    Thanks again
  • Tero Ahlfors
    July 22, 2013 at 4:31 am
    If the DVD doesn’t have any protections on it then you can drag the VOB files straight into Premiere.
  • Lynn French
    July 23, 2013 at 2:57 am
    Taking in all the advice- I drug the DVD content into my hard drive, imported it into premiere pro, edited it, imported into encore( not dynamic link) burned the new DVD and it worked just fine.
    Thank you all for your help!
  • Chris King
    August 4, 2016 at 2:37 am
    First, you can try to copy the .VOB files from your DVD(home made without copy protection) to your computer, then change the .VOB extension to .MPG and import. Usually Adobe Premiere could accept the files.
    Well, for those commercial DVDs, you need to move the copy protection and convert DVD to Adobe Premiere Pro editable file type. To convert DVD movies to Adobe PP, a DVD ripping tool is needed.
