Activity Forums Apple Final Cut Pro Legacy Ripping an SD DVD into Final Cut Pro
  • Ripping an SD DVD into Final Cut Pro
    Posted by Shawn Harrison on October 4, 2012 at 4:32 am
    Hi Guys,
    A client of mine needs me to edit down a film off a DVD. I honestly have done nothing like this in like 5 years. Most of the work I do comes in from a digital file source. What is the best program to do something like this these days? Are people still using handbrake? I assume I just need an app that will convert a DVD into pro res?
    Also how long will it take? It’s a 45 minute film that needs to be ripped. Total time with conversion about how long? Thanks in advance.
    Shawn Harrison replied 13 years, 10 months ago 2 Members · 2 Replies
  • Neil Patience
    October 4, 2012 at 5:37 am
    Yes you are correct MPEG to ProRes. Handbrake is still around although you might want to have a look at MPEG streamclip. Its a free download and will convert to ProRes quite happily – its a useful tool for all kinds of little easy conversion jobs. (Assuming DVD is not protected of course.) I would only be guessing in terms of how long – depends on what Mac you have to a degree – shouldnt take more than twice realtime but you can do 2 pass options for better quality which takes longer obviously.
    Either way shouldnt be too horrible in terms of time.
    Prores LT easily good enough for DVD quality.
    best wishes
    Neil
    http://www.patience.tv
  • Shawn Harrison
    October 6, 2012 at 3:44 am
    Thanks, that worked well. I just have a couple questions. I converted it to AppleProRes…regular. It has been so long since I worked in SD…What would be the best format I should rip the DVD to? It looks good but a little soft..How do you enable the 2 pass?? When I try to up the quality knob it won’t let me and is stuck at 50 percent…If you know any tips to get this as exact as possible I would really appreciate it. Thanks!
