Activity Forums Adobe Premiere Pro Ripping a DVD file for Premiere
  • Ripping a DVD file for Premiere
    Posted by Cl Beu on April 23, 2013 at 7:10 pm
    Hey y’all, I have some footage on dvd-r’s that I would like to rip in order to edit it in Premiere. I have been using Handbrake, and so far it has been working to rip the files into an MP4 format that is editable in Premiere.
    However, for some reason, one of the dvd-r’s that I’ve ripped into MP4 will not open in Premiere. I tried several times, re-ripping it, but still no luck. I then tried ripping it to an MKV file, and it opens fine outside of Premiere, but of course Premiere does not support MKV. I then proceeded to use Handbrake to turn the MKV into an MP4, but it still won’t open, in Premiere or outside of Premiere (with VLC).
    I’m confused as to why this is happening, any tips or suggestions would be much appreciated. Thanks!
    Kayla Wang replied 13 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
  • Ryan Holmes
    April 23, 2013 at 9:17 pm
    Handbrake is a less than ideal solution for what you’re doing. Handbrake is more intended for you to rip a DVD for use on your iProduct or Android device while taking that long flight somewhere. It’s not meant to rip the file into a quality format intended for editing.
    What you should be using is MPEG Streamclip – https://www.squared5.com
    Works for either Windows or Mac, and it allows you to rip the DVD off into a codec/format of your choice. It’s free to download and use.
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
  • Cl Beu
    April 24, 2013 at 2:55 am
    Thanks for the response. I tried using that program, and the same issue is happening. I can rip the file, but for some reason when I try and play the ripped version of it, it doesn’t work! Please, any suggestions would be helpful!
  • Ryan Holmes
    April 24, 2013 at 3:08 am
    Rip the file into a QuickTime .mov movie file using either DV NTSC, ProRes, or DNxHD as the codec. You could also make an AVI file if you are on a Windows box. Again, insert the codec of your choice into the AVI container and import into your NLE.
    Ryan Holmes
    @CutColorPost
  • Paul Neumann
    April 24, 2013 at 5:42 pm
    Try copying the .vob files to another drive and change the extension to .mpg.
  • Cl Beu
    April 24, 2013 at 7:32 pm
    Ah! Thanks so much for the help guys, yeah that worked Ryan! Thanks again!!
  • Jeff Pulera
    April 25, 2013 at 5:20 pm
    Why rip at all? Premiere supports NATIVE editing of the .vob files, just move from the disc to your hard drive and then Import them. That way you are not transcoding and adding quality loss. No need to change file extension, .vob is fine.
    Jeff Pulera
    Safe Harbor Computers
  • Ryan Holmes
    April 25, 2013 at 10:47 pm
    Jeff – I didn’t know that PPro could take VOB files right off the disc. That’s good to know. Nice tip.
    The reason I recommended transcoding is if he wanted to get to other apps for graphics or color correction. Those probably wouldn’t play as nicely with vob files.
    Ryan Holmes
    @CutColorPost
  • Kayla Wang
    August 2, 2013 at 7:32 am
    I prefer Aunsoft DVD ripper than Handbrake because the interface of handbrake is too complecated for me……
