Activity › Forums › Panasonic Cameras › Ripped dvcpro tape
  • Ripped dvcpro tape
    Posted by Ian Liuzzi-fedun on June 24, 2012 at 11:49 pm
    I have a dvcpro tape that ripped as I was pulling it out of our camcorder. I need to repair it. In the past I have just taken scotch tape and while I get a hit at that moment i can still recover the tape. Is there a better way to do this?
    Ian Liuzzi-fedun replied 14 years, 1 month ago 3 Members · 5 Replies
  • Noah Kadner
    June 25, 2012 at 4:50 pm
    Most post houses can do this for a fee- just depends where you are in the world.
    Noah
    Call Box Training.
    Featuring the Panasonic GH2 and Panasonic AC160/130.
  • Chris Tompkins
    July 27, 2012 at 1:17 pm
    I’d take care of it the way you have been.
    Chris Tompkins
    Video Atlanta LLC
  • Ian Liuzzi-fedun
    August 24, 2012 at 11:43 pm
    As a follow up:
    I am torn (no pun intended) between capturing in DVCPro HD or through the SDI output of the deck to my capture card and then real-time transcoding to ProRes. I know at the end of the day only the most technical and sensitive will be able to tell but since this is supposed to be a master, I want the best quality possible. Would capturing as ProRes give me an more latitude and help with compression concatenation or not?
  • Chris Tompkins
    August 25, 2012 at 1:04 am
    IMO, b/c it originates on DVCPROHD, you would not gain any noticable difference coming in via SDI to Prores. Unless;
    You were planning on many, many layers of grfx and rendering and compositing and more layers, multi-rendered etc.
    JMO
    Chris Tompkins
    Video Atlanta LLC
  • Ian Liuzzi-fedun
    August 25, 2012 at 1:14 am
    My thought exactly but they say you loose some with every generation so I am wondering if you loose less with transcoding to a better format.
