Activity Forums Boris FX Ring Of Fire ??
  • Ring Of Fire ??
    Posted by Accountclosed on February 21, 2006 at 12:21 pm
    i am realy stuck here i just want to create a ring of fire but can’t do this can anyone help me here if i use the fire plugin then there is (maybe)there’s not any option to make fire’s shape like ring or i just can’t make a curve in it so is there anyway that i can do it
    Thanks for your time
    Regards
    ALi
    Mark replied 20 years, 7 months ago 4 Members · 5 Replies
  • Tim Rice
    February 21, 2006 at 2:50 pm
    make a solid, add the fire filter, make a cylinder on a separate track and then drop the solid onto the face track of the cylinder. Then adjust the cylinder and fire to your liking…
    Hope this helps,
    Tim
  • Accountclosed
    February 22, 2006 at 5:17 am
    let me do this
    Thganks for your Help
    Regards
    ALi
  • Mark
    February 22, 2006 at 3:31 pm
    Or, create a big o with the text tool and use that as your map track….I suspect rendering might be a little quicker, and also a little easier to adjust.
    Mark
  • Amed Nasseri
    February 22, 2006 at 6:07 pm
    Hello Tim, and I’m sorry for jumping into this conversation, but I have a quick question, when you say a solid, is that mean a solid background? and what color? and how do you ad a fire filter?
    Thank you!
  • Mark
    February 22, 2006 at 7:18 pm
    I’m sure he means a 3d plane. Color doesn’t matter, as you won’t see it.
    sorry to answer for Tim…forgive me Tim 🙂
    Mark
