Activity Forums Maxon Cinema 4D rigid body dynamics not resting properly
  • rigid body dynamics not resting properly
    Posted by Andrew Donaldson on February 15, 2013 at 12:40 pm
    Hi cow folks.
    Ive got a problem with objects not resting properly on the ‘ground’.
    (I am using the latest iPod commercial ‘bounce’ as inspiration here)
    I have a simple scene with a modelled cell phone (connected and converted to a single object) on a floor. The phone has a rigid body tag and the floor has a collider tag.
    I am using a cylinder to ‘poke’ the phone from the floor to make it bounce. The problem I have is that the phone isn’t resting on the floor properly once it falls down. I have made sure the cylinder is well out of the way when the phone falls, but it stops before the floor as though it is resting on another object. But there is nothing in its way.
    Does anyone have any suggestions as to why it won’t rest properly on the floor?
    I am on C4D R13 studio on 2011 macbook pro, Lion, 8gb ram, etc.
    Thanks in advance.
    Andrew.
    Andrew Donaldson replied 13 years, 6 months ago 3 Members · 5 Replies
  • Darby Edelen
    February 15, 2013 at 4:38 pm
    [andrew donaldson] “Does anyone have any suggestions as to why it won’t rest properly on the floor?”
    What ‘Shape’ are you using for the phone? Is your Size Increment set to 0?
    Darby Edelen
  • Brian Jones
    February 15, 2013 at 4:40 pm
    in Project/Dynamics/Expert the default setting for Collision Margin is 1cm you can take that down to zero (or close)though if you are getting penetration of the floor you would have to increase the Steps per Frame/Iterations
  • Darby Edelen
    February 15, 2013 at 5:00 pm
    [Brian Jones] “in Project/Dynamics/Expert the default setting for Collision Margin is 1cm you can take that down to zero (or close)”
    While I wouldn’t rule out Collision Margin as a possible culprit, I wouldn’t start there either. Collision Margin doesn’t usually affect objects in such a dramatic way.
    Darby Edelen
  • Brian Jones
    February 15, 2013 at 5:47 pm
    depending on the scale and camera angle
  • Andrew Donaldson
    February 17, 2013 at 4:51 pm
    Hey, thanks for your replies.
    I think it might have been a bug, because a renamed the project and moved a few things around and its been fine since.
    If it happens again I’ll post back and will look into your suggestions.
    Thanks again.
    Andrew.
