Activity › Forums › Maxon Cinema 4D › Rigid Body does not work C4D R14.
  • Rigid Body does not work C4D R14.
    Posted by Daikiri Ichinose on November 1, 2012 at 9:18 am
    Hello,
    I am using Cinema 4d R14 Broadcast.
    Even though I click “Rigid Body”tag from simulation tags, it always turns into “Collider Body”.
    I tried the following steps, but it has not resolved the issue.
    1, Check off “Disable on Skip Frame”
    2, Inherit Tag>apply tag to children
    In Mogprah Cloner objects, simulation tags work fine.
    Could you kindly help me please?
    Thank you very much in advance,
    Dai
    Daikiri Ichinose replied 13 years, 11 months ago 2 Members · 2 Replies
  • Brian Jones
    November 1, 2012 at 2:26 pm
    in Broadcast dynamics are limited to Mograph objects but you can put objects you want to apply Rigid Body to into a Fracture object and put the tag on that.
  • Daikiri Ichinose
    November 5, 2012 at 9:21 am
    Thank you very much, Brian.
    It works perfectly!!
