Activity › Forums › Maxon Cinema 4D › rigid bodies hanging from splines
  • rigid bodies hanging from splines
    Posted by Jeremy Cox on February 22, 2010 at 5:45 pm
    I want two cubes, each attached to their own string, to drop into view, pull the splines tight, and bounce/swing until they stop, suspended in front of the camera. The rub is that I want the cubes to interact with each other, bouncing, spinning, etc.
    I have successfully gotten the objects suspended by splines using the C4D cafe “Swinging Objects using Spline Dynamics” example, but am at a loss as to how I should approach the interaction between the cubes.
    Any suggestions?
    Jeremy Allen replied 16 years, 7 months ago 2 Members · 1 Reply
