Activity Forums VEGAS Pro Right version for 64bit PC + the plugins…
  • Right version for 64bit PC + the plugins…
    Posted by Jack Mcgee on January 12, 2012 at 3:18 pm
    Wonder if you can help with this. I have Sony Vegas 9.0 32bit with various plugins and works perfectly fine on Win7 32bit
    I am getting a Win7 64bit system now with lots ram.
    If I upgrade to Sony Vegas 11 64bit. Would I still be able to use the old plugins? I want to use the old plugins at all costs.
    if there is going to be issues with plugins, I guess I should stick with the Begas 9.0 32bit? What difference would I see compared to the 32bit and 64bit version of Sony Vegas?
    Do you know if this older 32bit Sony Vegas 9 will run okay on Win7 64bit system? Will it utilise the 8Gb ram on the 64bit Windows 7?
    I am really confused here, since the main purpose of this new PC is video editing.
    I wonder what problems I may have with DVD architect also?
    Appreciate any advice you can give
    Rgds
    Peter.
    John Rofrano replied 14 years, 7 months ago 2 Members · 3 Replies
  • John Rofrano
    January 12, 2012 at 6:54 pm
    [Jack McGee] “If I upgrade to Sony Vegas 11 64bit. Would I still be able to use the old plugins?”
    No. 32-bit plug-ins will only load into the 32-bit version of Vegas.
    [Jack McGee] “I want to use the old plugins at all costs.”
    Then I would install Vegas Pro 11 32-bit. Going 64-bit means repurchasing everything you had before which is why many people stay on 32-bit.
    [Jack McGee] “What difference would I see compared to the 32bit and 64bit version of Sony Vegas?”
    You can edit and render much larger HD projects with 64-bit because it can use all of your memory. The 32-bit versions will only be able to use 2GB of memory.
    [Jack McGee] “Do you know if this older 32bit Sony Vegas 9 will run okay on Win7 64bit system?”
    It will probably work just fine. I believe Vegas Pro 9 supports Vista and so it should run fine on Windows 7 (which is just Vista without the bloat).
    [Jack McGee] “Will it utilise the 8Gb ram on the 64bit Windows 7?”
    No, 32-bit applications can only see 2GB of memory.
    [Jack McGee] “I am really confused here, since the main purpose of this new PC is video editing.”
    Most 32-bit applications will work fine on a 64-bit OS. They just run in 32-bit compatibility mode with 2GB of memory.
    [Jack McGee] “I wonder what problems I may have with DVD architect also?”
    DVD Archtect really hasn’t changed much with the last few releases on Vegas. It should work as well.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jack Mcgee
    January 12, 2012 at 11:56 pm
    John,
    I really appreciate your help. I am half wondering now why I have bothered paying extra money for Win7 64bit OS and 8Gb ram. One more question. Do you think I could install both 64bit and 32bit Sony Vegas on this computer?
    Then I could use 64bit for long HD projects (this going to be miniDV from HD camcorder)…and the 32bit for smaller FX files etc.
    Let me know your opinion.
    Thanks again
  • John Rofrano
    January 13, 2012 at 12:36 pm
    [Jack McGee] ” I am half wondering now why I have bothered paying extra money for Win7 64bit OS and 8Gb ram.”
    Well… if you didn’t plan on updating all of your software to 64-bit then you’re not taking advantage of a 64-bit OS and more memory. Still, you can run a lot more 32-bit apps simultaneously and all future purchases should be 64-bit so you will gain the advantage over time if you’re not willing to upgrade now.
    [Jack McGee] “Do you think I could install both 64bit and 32bit Sony Vegas on this computer?”
    Yes, absolutely. That’s how most of us continue to use our 32-bit plug-ins that aren’t available in 64-bit when needed.
    [Jack McGee] “Then I could use 64bit for long HD projects (this going to be miniDV from HD camcorder)…and the 32bit for smaller FX files etc.”
    Yup! or you could use the 32-bit version to apply an FX, render it out, and place the rendered footage back in your 64-bit project. That’s how you would do it with stand-alone FX apps like After Effects so why not with Vegas 32-bit.
    ~jr
