Activity Forums Apple Final Cut Pro Legacy right settings for animating
  • right settings for animating
    Posted by Fernando on May 23, 2005 at 4:34 pm
    hi- i have to animate some jpegs and tiffs for a video, but the picture quality im getting is not good enough since it has to go on a plasma screen. the pictures’ resolution is good enough ( 300 dpi ) so there must be something wrong with the formats and settings im using. could anyone direct me as to which format the pictures should be in ( tiff, png etc. ) and which are the best sequence and export settings? i would really appreciate the advice, kind of desperate and short of time!
    thank you, good cow folks
    Gunner Jones replied 21 years, 3 months ago 4 Members · 3 Replies
  • Geof Gilland
    May 23, 2005 at 4:51 pm
    What resolution is your plasma screen? Many times, when going to a plasma or lcd monitor, the best results can be obtained from using the “native” resolution of the plasma….such as 1024 x 768, etc. Also, is the plasma running 720p or 1080i? All this information is needed to get an ideal resolution.
  • Tom Matthies
    May 23, 2005 at 5:08 pm
    Make sure that you render all of your still clips in the timeline. Often when you animate them, FCP will attempt to play them back in realtime but at a lower resolution. Everything will look fuzzy. Select the clips and force them to render and things should look better.
    Just a thought…
    Tom
  • Gunner Jones
    May 23, 2005 at 6:06 pm
    Fernando,
    First of all, you probably are not rendering properly nor are you monitoring your rendered effects properly.
    First read this:
    https://www.kenstone.net/fcp_homepage/rendering_rt_fcp_4_balis.html
    What should you learn from that article?
