Activity Forums Audio Right Frequency Lav
  • Right Frequency Lav
    Posted by Mike Damian on April 25, 2014 at 5:38 pm
    I’m looking to invest into a Sennheiser ew 112-p G3 wireless lav. There are 3 versions, with 3 different frequency ranges. How do I know which one to get? I live in Phoenix, AZ and that’s were I will mainly be using it. I looked up my zip code on Sennheiser’s frequency finder but I don’t understand the results it came up with.
    https://en-us.sennheiser.com/service-support-frequency-finder
    Here are the 3 choices.
    A/516-558 MHz
    B/626-668 MHz
    G/556-608 MHz
    Craig Alan replied 12 years, 4 months ago 2 Members · 1 Reply
  • Craig Alan
    April 26, 2014 at 10:34 pm
    click on HELP under RESET it will explain chart.
    also keep in mind:
    the FCC is currently considering auctioning off the 600MHz – 700MHz range which could happen as early as 2015.
    470 – 600 MHz should, for now, be future proof.
    any time you use a cordless kit you need to do a sound check to make sure something in the air is not causing problems. The unit has a built in scan function to help you find a free channel. Some times nothing works and you need xlr backups.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
