Activity › Forums › Compression Techniques › right compression for television – 16:9 anamorphic
  • right compression for television – 16:9 anamorphic
    Posted by Marta Mancusi on September 12, 2013 at 9:40 am
    Hello everyone, I have a question about compression for television,
    I have to submit a 30 seconds video for an italian television. They asked me a 16:9 anamorphic format and the video has to be maximum 10 M.
    I exported the video in full HD from after effects. Then I imported it in Adobe Media encoder and exported it again using the PAL DV Wildscreen 25fps preset/format Quicktime.
    Is that correct for a 16:9 anamorphic file?
    I got a video that is 108,5 MB. How can I compress it to get to a 10 M file, not loosing the 16:9 anamorphic format?
    Any help is appreciated!
    Thank you very much
    Marta
    Ivan Myles replied 13 years ago 3 Members · 3 Replies
  • Craig Seeman
    September 12, 2013 at 2:30 pm
    Basic high school math.
    A car going at 100 kilometers per hour travels two hours has traveled 200 kilometers.
    kbps times duration equals file size.
    Don’t take it personally but I don’t know why this math seems to be such a challenge for anyone who graduated high school let alone college.
  • Craig Seeman
    September 12, 2013 at 2:49 pm
    BTW, you can’t change the data rate for DV. It’s built into the codec.
    If they’re giving you data rate along with the duration, they can’t be asking for DV.
  • Ivan Myles
    September 12, 2013 at 4:44 pm
    To expand on Craig’s comments, QuickTime DV is available at 25mbps and 50mbps. A 30-second video stream will require 94MB at DV25 or 188MB at DV50. With the audio and overhead included 108MB sounds about right.
    DV is an all intra-frame format. In order to compress the file to 10MB, use a codec like H.264 or MPEG-2 that incorporates inter-frame compression.
