Activity › Forums › VEGAS Pro › Right Click Crash “Unmanaged Exception (0xc0000005)”
  • Right Click Crash “Unmanaged Exception (0xc0000005)”
    Posted by Barry Breckinridge on May 30, 2011 at 2:58 pm
    This problem seems to have started suddenly after working with an audio recording project for many days. If I right click in the gray area of the Audio Header Vegas will crash & shut down. I don’t recall changing any settings or preferences & I have been the same plugins…in other words I am doing what I have been doing all along, but this morning Vegas decided to throw this curve-ball. Any ideas would be appreciated! Thanks
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0d (Build 669)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 10.0\Vegas Pro 10.0\vegas100.exe
    Fault Address: 0x007C3B5E
    Fault Offset: 0x003C3B5E
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 10.0\Vegas Pro 10.0\vegas100.exe
    Process Version: Version 10.0d (Build 669)
    Process Description: Vegas Pro
    Process Image Date: 2011-05-05 (Thu May 05) 23:19:40
    Stephen Mann replied 15 years, 4 months ago 4 Members · 3 Replies
  • Barry Breckinridge
    May 30, 2011 at 3:34 pm
    I think I found the problem & it seems to be related to Audio ASIO hardware in this case. Hindsight is 20/20 & I think I know what I did…
    During a multi-track recording session I had been using 2 linked Delta 1010 sound cards to allow me to record more than 8 tracks simultaneously. For mixing purposes, I only need one delta 1010, so I removed the second sound-card (I’m not sure I needed to remove it but have had issues in the past with syncing & word clock when linking 2 together so I thought better to just remove one after not needing it anymore)
    Somewhere it was mentioned that the error might be related to audio drivers (thank you John) So I went back to preferences & changed my audio hardware from the Delta ASIO to “Sound Mapper”, right clicked in the area and no crash! I then reset the audio device back to the Delta 1010 ASIO & no crash! It was just a lucky try…but seems to be working for now. Apparently Vegas Software was looking for the second sound-card even though the hardware and drivers were removed, I guess because when I created the projects I had both instances of the sound-card in the project. So it seems that what I did “refresh” the software….
  • Stephen Crye
    May 30, 2011 at 5:12 pm
    Hi;
    I get this or similar all the time now. Not correlated with a specific project or sequence of events. I’m convinced it is yet another bug – grrrr. Hopefully if we all send in the crash reports Sony will fix it.
    Sadly, 10d seems to crash more than did 10c. I’m not a happy camper.
    Steve
  • Stephen Mann
    May 31, 2011 at 3:17 am
    [i]”I’m convinced it is yet another bug – grrrr.”[/i]
    The OP says that he found his problem *in the drivers*, (user-induced, at that), yet you still blame Vegas???
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
