Activity Forums Adobe After Effects Expressions Right align text box + corresponding shape layer
  • Jarle Leirpoll
    October 20, 2017 at 5:16 pm
    Unfortunately not. The usual method is to make two layers and set Opacity expressions. Or you could keep each line on separate layers (using split expression if you want only one text field in the mogrt) and position each layer (and the shape layer) relative to the width with expressions.
    Jarle Leirpoll
    PremierePro.net
