Activity Forums Maxon Cinema 4D Rigging this LEGO
  • Cactus Dan
    August 8, 2015 at 7:39 pm
    Howdy,
    You can skin each mesh only to it’s respective joints. If the model parts are not supposed to bend, then you need to create a different rig than what you’re showing in the screen shot.
    Adios,
    Cactus Dan
    Cinema 4D R13 Prime
    http://www.cactus3d.com
    http://www.cactus3d.com/Plugins.html
  • Antonio Petit
    August 8, 2015 at 8:29 pm
    Yes, finally!.
    I skinned the hands to joint #2 and same for the arm so when i move Joint #2 it moves all the arm.
    Thanks for the advice!.
