Riddled with Reverse Field Dominance – Take 2
So I’ve been working on converting a popular 1960’s TV series into the PAL format. The film was telecined to NTSC DigiBeta.
I was hoping to reverse telecine it (using Compressor), add bar and tones in FCP and render to a QT file (at 23.98 fps). I’d then take the file, conform it (using Cinema Tools) to 25fps and then finally run it through Compressor to make the frame size correct for PAL. (All of this using ProRes 4:2:2 files).
So this all worked out perfectly (or so I thought). It is beautiful. I then needed to convert the final PAL file to a MXF using Episode Pro (IMX-50 Op1a format) to send off to the network. The MXF file looked great using VLC player.
I do all of this and then got told that my test file was “riddled with reverse field domination” and therefore rejected.
How could this happen? I made sure that “Top Field” was selected throughout my workflow. The one thing is that the original material was captured in Lower Field (using a Matrox Mini), but I don’t have a choice with this evidently. Also, it seems that by selecting TFF my final workflow would fix this?
So the question too is can a clip change field domination while playing? Or is the clip one domination or the other?
PAL files are supposed to be TFF? Right?
Any insight or help would be appreciated. I’m not finding many people that work with MXF files…
Is there a program (Mac or PC) that will analyze a file and tell you the true field order and if there are issues? I’ve used Compressor and pulled up the “inspector” window and it always says TFF.
