Activity Forums Maxon Cinema 4D Ribbon flutter while moving on path
  • Ribbon flutter while moving on path
    Posted by Rich Carroll on June 24, 2005 at 10:45 pm
    I’m trying to make a ribbon flow through a scene. I’ve got Path Deformer working nicely (great plugin BTW). But the ribbon looks a bit fake because the tail is following the head perfectly along the path. How can I add a flutter to the back of the ribbon, so it diverges from the path? Is there a way to make a cloth structure and then use path deformer (I’ve been trying to get this to work to no avail)
    Jason Richards replied 21 years, 2 months ago 3 Members · 4 Replies
  • Lennart Wåhlin
    June 25, 2005 at 12:07 am
    Paint a Vertexmap and use it as restriction for a FlagDeformer.
    Just tried and it works and looks good.
    Cheers
    Lennart
  • Jason Richards
    June 27, 2005 at 7:56 pm
    explain, im confused. If i have a extruded spline and use path deformer do i need to make my extruded spline an editable object. I got it to work, but it doesn’t look right
    thanks
    JR
  • Lennart Wåhlin
    June 27, 2005 at 9:59 pm
    Please have a look a Item026 at.
    https://homepage.mac.com/tcastudios/TCA%20CINEMA.html
    It is a zipped Cinemascene.
    Keep any deformers above Pathfinder to prevent strange distortions.
    Cheers
    Lennart
  • Jason Richards
    June 28, 2005 at 4:56 am
    awesome, thanks
    JR
