Activity Forums Adobe Premiere Pro RGB (Y,Pb,Pr) Fx540 Output to Sony Trinitron
  • RGB (Y,Pb,Pr) Fx540 Output to Sony Trinitron
    Posted by Ninetto Makavejev on June 27, 2006 at 10:02 am
    I am running PremPro 2.0 with a Quatro fx540. I was using the S-VHS to output to the SONY Trinitron Monitor, but tried to change the output using the RGB breakout box. With PAL-DV material I cannot get the monitor to display properly, or the signal from the fx540 has the wrong settings. I get only green or blue “masked” output. Any ideas on this? Another naive question: does it make sense to output DV to RGB (Y,Pb,Pr) or is this signal specially for HDV? Thanx…
    regards, n.m.
    Ninetto Makavejev replied 20 years, 2 months ago 2 Members · 2 Replies
  • Tim Kolb
    June 27, 2006 at 3:31 pm
    RGB and Y’,Pb,Pr are two different signal types. The breakout box on the FX540 only outputs Y’,Pb,Pr.
    If the monitor has true RGB inputs…for use from a DVD player for example, the signal will never display properly. If the monitor has component video signal input, sometimes labeled as Y, Pb, Pr or Y, R-Y, B-Y, then the signal should work and you may have a cable crossed to cause this issue…
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Ninetto Makavejev
    June 27, 2006 at 4:33 pm
    Thanks much for your explanation.
    I will check the monitor’s specs, but I do believe it has true seperate component inputs. It’s just that I have to delve thru 2 sub-menus: the one on the monitor, which is complex enough, and then setting up the FX540 outputs in the graphic-card menu(s)… I wish this was easier!
    best regards, n.m.
