Activity Forums Adobe After Effects RGB SPlit
  • Posted by Sergej Glacier on February 24, 2018 at 8:11 am
    Hey, i want to make an RGB Split, and i know how, it’s just that i need to make the rgb split on a 3d object, it is the same as 2d i know, but i need to have 3 copies of object: red, blu and green, so that means i need to have three 3d objects just for the split, does the alternative technique exists
    Plese help
    Dirk De jong replied 8 years, 5 months ago 2 Members · 1 Reply
  • Dirk De jong
    February 24, 2018 at 8:41 pm
    [Sergej Glacier] “but i need to have 3 copies of object: red, blu and green”
    There are 3rd party plugins that would avoid that for you, or at least without plugins (if your 3D object is really render intensive) maybe you could precompose the 3D object and use 3 copies of the precomp instead which could be significantly more efficient
