Activity Forums Adobe After Effects RGB Split in displacement?
  • RGB Split in displacement?
    Posted by Joey Deutsch on March 27, 2014 at 12:25 am
    I noticed this effect a while ago in a youtube video. Basically, when a Displacement map was used on a VFX shot, wherever the displacement was happening there was this really neat RGB fringe. I know how to do a basic RGB split, but how would I only apply it to areas affected by a displacement map?
    George Goodman replied 12 years, 5 months ago 2 Members · 3 Replies
  • George Goodman
    March 27, 2014 at 1:17 pm
    The effect is called chromatic aberration and there are a lot of ways to do it. One way that gives you a very manual approach and lots of control is to copy the footage and use the channel effect to create the red green and blue channels.
    Theres tons of tutorials on how to do it though, look to see what suits your needs best.
    “|_ (°_0) _|”
    Sincerely,
    George
  • Joey Deutsch
    March 27, 2014 at 5:37 pm
    Thanks! Now how do you think I could apply it only to areas affected by a displacement map? Do you think I should use the displacement map as a matte on a separate chromatic aberration layer of the footage?
  • George Goodman
    March 27, 2014 at 5:47 pm
    I’m not sure I understand exactly what you’re trying to do, but I think the answer would be to precompose the layer that has the chromatic aberration effect, change the blend mode to overlay and use it with the displacement map.
    “|_ (°_0) _|”
    Sincerely,
    George
