Activity › Forums › Adobe After Effects › RGB Preview
RGB Preview
Posted by Stuart Smith on September 18, 2008 at 2:28 pmHi all,
I’ve noticed something in CS3. The R/G/B/Alpha pulldown button, next to the Full/Half/Quarter resolution button has a yellow cross in the centre of it. Has that cross always been there, or is it something new for CS3? It still appears to work the same as in AE7 though.
StuartAzariah Owens replied 18 years ago 3 Members · 7 Replies -
Darby Edelen
September 18, 2008 at 5:06 pmThe plus was new in CS3 and means you’re looking at the RGB channels with alpha transparency (as opposed to straight RGB).
…I believe.
Darby Edelen
NVIDIA
Santa Clara, CA -
Stuart Smith
September 18, 2008 at 5:21 pmah, got it, it’s when the working space is set to something other than none.
Stuart Smith
September 19, 2008 at 10:59 am🙂 thanks. Solved it by sheer luck. Trying to find a solution to the ridiculous gamma shift problem between FCP and AE and noticed it appear and disappear.
Azariah Owens
September 19, 2008 at 6:25 pmThat Yellow + sign means you have color management turned on. Which may explain why you are getting gamma shifts when you import into FCP. What color space are you using?
Stuart Smith
September 19, 2008 at 6:46 pmHey, thanks. Unfortunately this gamma shift isn’t a color space problem, this is something that has been a problem for quite some time between FCP and AE. Why Apple and Adobe can’t sort this out is beyond me and it seems to be even worse with Red footage. There are quite a few threads about this problem so we probably shouldn’t start another one. But if you’re interested in it check out this thread
https://forums.creativecow.net/thread/2/919924
or google FCP AE color shift
