Activity › Forums › Adobe After Effects › RGB Disperencies – illustrator and after effects
  • RGB Disperencies – illustrator and after effects
    Posted by Chris Straus on January 7, 2011 at 7:32 pm
    hi
    i have a logo that is an rgb illustrator cs4 eps color 227,27,35. i import that into an after effects 7 document. in there i create a colored layer and give it the same red color value, however the reds are slightly different. how can i overcome this?
    Chris Straus replied 15 years, 8 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    January 7, 2011 at 7:42 pm
    Check to see if you have the same color working space in AE and AI.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Straus
    January 7, 2011 at 7:45 pm
    thanks guys, just realized it was an issue of importing a vector graphic from a illustrator cs4 into after effects 7. i guess that after effects 7 must have issues with programs newer than itself, once i saved down the image to illustrator cs all worked fine.
