Activity › Forums › Apple Final Cut Pro › RGB + Alpha out of FCPX
  • Ian Bailey
    October 16, 2012 at 2:53 pm
    Export your media using the ProRes4444 codec. I’ve not tested this with AE, but if it’s CS5.5 or CS6 and you’re using it on a Mac, I would expect this to work.
  • Mathieu Ghekiere
    October 16, 2012 at 6:44 pm
    I’ve often made some titles in FCP X, exported them as Prores 4444, and used them in FCP 7 above other layers, works perfect.
