Activity Forums AJA Video Systems RGB 10-bit magic settings
  • RGB 10-bit magic settings
    Posted by Andrew Dietz on March 25, 2010 at 6:26 pm
    System specs: Snow Leopard 10.6.2 w/both versions of Quicktime installed.
    Kona 3 7.5.1 (also used 7.5.0)
    Final Cut 7.0.2 (also used 7.0.1)
    HDCAM SR – SRW-5800
    Tektronix 7020 scope
    I am capturing RGB 10-bit material from HDCAM-SR with SMPTE range. I am able to capture/output no problem if I use the Bars & black signal that originate from the tape.
    Any blank spots, or slug will cause the blacks to dip below 0mv. Also, using any stills or other non-RGB footage (such as Animation) will render fine if I don’t use any effects such as a dissolve or crop. Once I apply any effect/filter/motion, the overall levels change.
    My sequence is setup to render in RGB. I have heard rumors about some secret magic way to get RGB to render correctly in 10-bit. Trashing Quicktime prefs? Imported Still/RGB Video gamma setting?
    Any insight would be appreciated, and possibly result in more sleep.
    Doug Beal replied 16 years, 5 months ago 2 Members · 1 Reply
  • Doug Beal
    March 29, 2010 at 4:52 am
    It seems to me that opacity changes and exporting still frame and possibly other manipulations occur as YUV effects not RGB even if you’re set up RGB.
    If I paste 10bit RGB footage into a 10bit uncompressed sequence and render I don’t have luma/color issues in playback and the resulting darkening when stopped or parked on a frame.
    Even though I set up a 10 bit uncompressed timeline I still render in RGB.
    when I import the footage (file based DPX to RGB quicktime AJA xlater) I have the Gamma set to 2.2 for RGB images. after all’s put together I copy the RGB sequence and paste to a 10bit uncompressed sequence and render.
    Life becomes beautiful
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
