Activity Forums Apple Final Cut Pro Legacy RF noise on interviews
  • RF noise on interviews
    Posted by Ross Marshall on January 9, 2008 at 2:32 pm
    Currently editing a documentary where the cameraman has filmed all the interviews, using radio mics. Problem is we can hear a lot of RF noise from the mics on the footage. Is there any way of geeting rid of this.
    cheers in advance
    Ross
    Peter Sturken replied 18 years ago 3 Members · 2 Replies
  • David Bogie
    January 9, 2008 at 2:58 pm
    SoundtrackPro can be taught to understand, search for, and eliminate much of the offending noise values. However, RF, even though it is fairly narrow band of frequencies, is typically omnipresent and obtrusive. Attempting to filter it out is likely to remove lots of other audio information.
    I’m not at that machine now or I’d try to be more help, someone else will be along in a few hours to be more specific.
    See the online manual for STP. Look for noise removal (but that’s not what the function is actually called.)
    One must ask how such incompetency was allowed to continue past a quick mic check and test recording. Tehre is another kind of wireless mic interference that cannot be heard while recording. It is caused by microwave-based motion scanners and old-style room occupancy sensors. This stuff cannot be removed. We’ve tried everything.
    good luck.
    bogiesan
  • Peter Sturken
    August 22, 2008 at 5:27 pm
    I’ve got the same problem… did anyone propose a solution? I’m only half way through the manual, but plowing ahead.
