Activity › Forums › Panasonic Cameras › RF Error Alarm using the Varicam. Has anyone else experienced it?
  • RF Error Alarm using the Varicam. Has anyone else experienced it?
    Posted by Ray Palmer on August 4, 2005 at 7:37 pm
    Our Varicam will occasionally provide us with an RF Error alarm while recording. The display window on the side of the deck displays “RF” and the alarm beeps five times. It also sounds like the servo looses lock and the tally light blinks. After a few seconds, the camera operates normally until the next RF error.
    Question-Has anyone else experienced this feature? If so, what did it take to repair it?
    Later,
    Ray
    Ray Palmer, Engineer
    Salt River Project
    Phoenix, AZ
    602-236-8224 office
    There are three types of people in this world, those that can count and those that can’t.
    Rodrigo Lizana replied 21 years, 1 month ago 4 Members · 5 Replies
  • John Sharaf
    August 4, 2005 at 10:23 pm
    Ray,
    I have to say that I’ve experienced a similar phenomenon several times; I have no explaination other than perhaps a dirty head or maybe a tape drop out. All I could recommend is a good head cleaning. Let us know if this persists!
    JS
  • Ray Palmer
    August 4, 2005 at 10:43 pm
    John, you are spot on.
    I cracked open the camera case and cleaned the Scanner, Drum, Head or whatever you want to call it.
    It was dirty and I got a lot of oxide off of it.
    Before I cleaned it, it was failing every 2-3 minutes with an RF alarm. After cleaning, I have been able to run an entire tape through it three times now without an error.
    Life is good.
    Thanks John,
    Ray
    Salt River Project
    Phoenix, AZ
    602-236-8224 office
  • Mariusz
    August 5, 2005 at 4:40 am
    Ray,
    One more thing that should be also done is to replace cleaning roller. Camera uses that roller not only to automatically clean heads when they get dirty but also to stop drum from spinning when you press stop.
    If you had a problem with RF I am sure that roller is dirty too and it will make heads dirty again that will lead to the same problem soon. Panasonc authorized service centers have them available for replacement.
    Regards,
    Mariusz Cichon
  • Ray Palmer
    August 5, 2005 at 3:22 pm
    Good Idea. Thanks for the note.
    Ray
    Salt River Project
    Phoenix, AZ
    602-236-8224 office
  • Rodrigo Lizana
    August 7, 2005 at 3:18 am
    Ray : You should take good note of what Mariusz told you. We works very closely with the Varicam at Abel Cine Tech in NY so I believe it
