Activity Forums Apple Final Cut Pro Legacy Rewrite timecode of captured file.
  • Rewrite timecode of captured file.
    Posted by Rodrigo Silvestri on October 30, 2010 at 1:35 am
    Hi. I captured some DV footage with broken timecodes and drop frames. I set FCP not to stop after a tc break, neither after a dropped frame, so when it ended it warned me of the tc problems.
    I don’t care about the tc of that footage, it won’t be recaptured. Is there a way to delete the tc and replace it with a new perfect tc?
    Rodrigo.
    Some people seem to love getting angry. I don’t 🙂
    Chris Borjis replied 15 years, 10 months ago 3 Members · 2 Replies
  • Michael Gissing
    October 30, 2010 at 1:48 am
    If you ignored timecode breaks then the file will have a continuous timecode. There is no need to change this.
    However if you wish to completely burn the slight bridge back to the tape then try this –
    https://www.videotoolshed.com/product/42/qtchange
  • Chris Borjis
    November 1, 2010 at 5:10 pm
    or open it in fcp, then goto “modify”, “timecode” there you can set the reel, timecode and drop, non-drop settings. fcp will then change the clips time code.
