Activity Forums Adobe Premiere Pro rewrapped XAVC not viewable
  • rewrapped XAVC not viewable
    Posted by Chad Greene on April 30, 2018 at 11:00 pm
    I have some footage shot on the Sony F5 that was originally imported by Final Cut Pro X. On the card it was .MXF and then rewrapped as .mov by X.
    Now when I import this footage into Premiere it comes in as audio only. The footage plays fine in the Finder, Quicktime and X. Any ideas on how to get this media to work in Premiere?
    Chad Greene replied 8 years, 4 months ago 4 Members · 10 Replies
  • 10 Replies
  • Chad Greene
    May 1, 2018 at 2:57 pm
    I am sorry Dave. I had the codec only in the title of this post. But here is more detail.
    Final Cut Pro X sees the original .mxf file as “XAVC Intra 422/10 Class 300”
    and the rewrapped .mov file as “XAVC 4K 24p”
    Chad Greene : Mahoney Media : Minneapolis, Minnesota : 2×2.66 GHz 6-Core Intel Xeon, 12GB Ram, OS 10.11 FCPX, Kona-LHi
  • Chad Greene
    May 1, 2018 at 6:08 pm
    It is strange that the codec works in X but not in Pr.
    I brought the same file in to X, Resolve and Premiere. X and Resolve can see and play the file. Premiere can not. It doesn’t sound like an uninstalled codec. What am I missing?
  • Greg Janza
    May 1, 2018 at 6:14 pm
    can you upload a small .mxf clip?
    Windows 10 Pro
    i7-5820k CPU
    Nvidia GeForce GTX 970
    Blackmagic Decklink 4k Mini Monitor
    Adobe CC 2018
    Renders/cache: Samsung SSD 950 Pro x2 in Raid 0
    Media: Samsung SSD 960 PRO PCIe NVMe M.2 2280
    Media: OWC Thunderbay 4 x 2 Raid 0 mirrored with FreeFileSync
  • Chad Greene
    May 1, 2018 at 8:59 pm
    Greg here is a 3 second .mxf file straight off the camera and that same shot rewrapped as a .mov file.
    https://drive.google.com/drive/folders/1LABBKHjUa5Eesy0FsHHXkTIeP_JrWkbD?usp=sharing
    Here is what I see when I import into Pr.
  • Greg Janza
    May 2, 2018 at 5:14 am
    I imported your files and I get the same results but isn’t it irrelevant since the original files work just fine in Premiere.
    Windows 10 Pro
    i7-5820k CPU
    Adobe CC 2018
  • Tero Ahlfors
    May 2, 2018 at 7:21 am
    [Chad Greene] “Premiere can not. It doesn’t sound like an uninstalled codec. What am I missing?”
    The file is using an Apple specific pro codec that is not found in Premiere. The latest Premiere only has support for their own encoder/decoder for Quicktime and it will not read any installed external codecs.
    Is there a reason you can’t use the camera originals in Premiere?
  • John Pale
    May 2, 2018 at 2:24 pm
    Premiere Pro now uses its own internal engine to decode Quicktime files. There are fewer codecs supported than before. Mostly this affects older codecs, that are seldom used, but in this instance its biting you in the butt. Use the original MXF files, if you can.
  • Chad Greene
    May 2, 2018 at 4:22 pm
    [John Pale] “There are fewer codecs supported than before. “
    Hmm I wonder if there is a workaround. For the last 5 years we have been filming for a documentary series, then importing to FCPX (rewrapping the media). Now we are talking about letting new editors rough cut in Premiere (where they are more comfortable), but currently they can’t see our media and it would take a huge effort to rewrap back to .mxf or transcode to something else.
    If I can get this Apple flavored codec to work with Premiere, then our editors can choose what tool they want.
  • Tero Ahlfors
    May 2, 2018 at 5:01 pm
  • Chad Greene
    May 2, 2018 at 5:10 pm
    That looks good except it is Windows only. We are all Mac.
