  • Matthijs Van noort
    March 2, 2011 at 12:20 am
    Yes, that works and it’s free. But be aware, it takes a very long time. Quicktime can either ‘rewrap’ or ‘rerender’ with help of Perian.
    Rewrapping is quite fast, but I had problems with the ‘rewrapped’ file, so I had to rerender anyhow. Rerender took forever, both with quicktime as well as with adobe. It’s definately not a fast way to go. I think bottleneck is the quicktime component.
    It was 40 hours against one hour in my case.
  • Benoit Côté
    December 12, 2011 at 11:47 pm
    You can open your mkv with Quicktime (and perian installed) Save As Ref movie to have a MOV container of you mkv, open it with MPEG Stream Clip and export it to Prores.
    MPEG Stream Clip is quite fast for reencode…
  • Tomasz Huczek
    June 27, 2015 at 12:38 pm
    You can also use VLC player to convert MKV file into m4v (mp4).
    Here’s a short description:
    https://timeinpixels.com/2015/06/using-matroska-mkv-clips-in-premiere-pro/
Page 2 of 2
