Activity Forums Apple Final Cut Pro Legacy Reworking .MOV file for edit and export
  • Reworking .MOV file for edit and export
    Posted by Christopher Bagnall on February 20, 2006 at 9:28 pm
    I’ve got a .mov file that I edited a while back iMovie before I knew FCP. I now want to rework some things creatively in the movie and export this as a smaller size but for some reason when I import in to FCP, it’s choppy and sort of unmanagebale. Any suggestions?
    Shane Ross replied 20 years, 7 months ago 2 Members · 2 Replies
  • Christopher Bagnall
    February 20, 2006 at 9:33 pm
    I fixed the issue. Sorry for the extraneous posting.
  • Shane Ross
    February 20, 2006 at 10:12 pm
    Use QT PRO to export it as DV/NTSC:
    #20 Using iMovie to Capture for FCP edit
    Shane’s Stock Answer #20:
    iMovie handles the media differently from FCP, specifically where audio is concerned. So it is not a recommended workflow. Here’s why…
    iMovie captures using DV Stream (.dv) standard which does not use timecode. That is a big disadvantage over the way that FCP captures in that you can’t go back and recapture the material at a later date if you need to revisit a project.
    The DV/NTSC specification (the one FCP uses) also calls for seperate tracks for audio and video, even if you capture it as one clip. iMovie’ DV stream format is muxed audio and video, which means that they are tied together (I can’t get into specifics because I ain’t no engineer or programmer). FCP is a bit more demanding and captures the seperate audio/video tracks, either in a single media file or as seperate video and audio files. With FCP you could capture video only or audio only because each is defined by the DV specs. while with iMovie you can’t.
    Also, if you drop the iMovie footage into the timeline, your will get the RED render bar forcing you to render the footage in order to see it…
    Shane
    Alokut Productions
    http://www.lfhd.net
