Revisiting: sound cancelling headphones for monitoring recording
Posted by Tom Galli on January 12, 2020 at 9:00 pmAloha all!
I know, the dogma is “sound-cancelling headphones color sound, and as such, are evil.” I am questioning the dogma, though, and my last shoot reminds me why. We were outdoors. It was intermittently quite windy. And, there was a generator.
I wear full-coverage headphones (Senal SMH-1000 that day), which do provide some isolation from environmental sound, but only some. I seriously doubt it’s 20dB, but I can’t find a published number. Regardless, with the headphones over my ears, I could still hear the generator. But because I was hearing it, I couldn’t tell if I was getting it on the body mics that were another 30 yards away.
Just for giggles, I even put a pair of hearing-protection earmuffs on. That’s 32 dB of isolation, if the packaging is to be believed. I could still hear the generator in the distance. It wasn’t loud, but if I listened for it, it was there. So, even if my monitor headphones had that kind of isolation, I’d still question “am I hearing it in the recording, or just as leakage through my headphones?”
It’s beginning to seem to me that sound-cancelling technology could remove that doubt. A little inaccuracy in the frequency response might be a small price to pay in order to be sure that the signal is clean.
Anyone have thoughts on the matter?
Mahalo,
Tom GThe difference between theory and reality is that, in theory, there is no difference between theory and reality.
Tom Galli replied 6 years, 7 months ago 4 Members · 14 Replies -
Ty Ford
January 13, 2020 at 3:37 amHello Tom and welcome to the Cow Audio Forum.
Big answer: Don’t do it.
Little answer: Get a DNS-2 instead.
https://tyfordaudiovideo.blogspot.com/2016/08/the-cedar-dns-2-portable-dialog-noise.html
With the noise coming from a nearby generator, I’d say you don’t have a noise problem. You have a location problem.
Regards,
Ty Ford
Cow Audio Forum LeaderWant better production audio?: Ty Ford\’s Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford\’s Blog -
David Peterson
January 14, 2020 at 10:52 pmActive Noise Cancelling headphones are a HORRIBLE idea.
I feel your pain though when it comes to generators:
https://www.youtube.com/watch?v=YEjk_oZo4pUDid they do the absolute MAXIMUM they could to deal with the generator? First of all, hire it from a proper film rental house (as they’ll stock quieter generators), not from a building/construction/etc rental house. Second, position the generator as FAR AWAY AS YOU CAN (see my video, it was waaay up a hill and down the other side by the road, and even though I wish was much further away). Third, what angle is the generator pointing? Often one side of it will be louder, and spinning the generator around 180 degrees makes a noticeable difference. Fourth, can you position anything between you & the generator? Putting a generator on the other side of a low stone wall might only be moving it by a few feet further away, but can make a bigger difference to the sound than the distance might suggest!
What you need (well, other than first you need to be dealt a better hand! These are not so much sound problems, as a location or electrical problem) is Remote Audio HN-7506
https://remoteaudio.com/products/hearing/high-noise-headset/
They’re much much cheaper than a Cedar DNS2 (although I love this too! I own a DNS2 myself, but you could just leave it to be handled during sound post. Which is where it is meant to be), and HN-7056 addresses directly the problem of being able to monitor what’s being recorded vs the DNS2 which just tries to hide/”fix” the problem. (although, get a DNS2 as well if you can, it truly is magical! But this is very much a luxury purchase)
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Tom Galli
January 15, 2020 at 12:22 amIt’s funny to me how the replies are focusing on the generator. That was only the example from my most recent shoot, but it seems to be that, by its very nature, location recording means dealing with noise. Every time I’ve been in charge of recording audio on location, and sometimes even on a sound stage, at some point I have asked myself “am I hearing that as part of the signal, or am I hearing it because the sound is penetrating my headphones?” Clearly spending $3k on a filter for the mic will not change that question at all.
I do like the headphones you listed, and may well pick up a pair. Are they comfy enough to wear for a full day? They look like what I wear when I go shooting (the other kind), and those are definitely not comfortable enough for extended use.
What makes you say that noise cancellation is a “horrible” idea? This is the idea I’m interested in discussing. I get that there’s concern about the sound-cancellation circuitry inadvertently coloring the sound, but when the quest is for clear sound, is a little false color really a sin? It’s not as if I’m EQing in the field.
David Peterson
January 15, 2020 at 1:38 amThey’re not as comfy as the MDR-7056 they’re based on, as they do seal quite firmly around your head. (or maybe I just have a big head!) But yes, people do use these all day long. You’ll see a pair of these being used on many pro sound mixers’ carts.
If you ever get a chance to try out the Cedar DNS2 then do give it a go, the results will simply astonish you. Cedar has taken their very expensive high end big rack mount units and squeezed it all into a super small portable unit. I’ve used it often in my bag, as it is just that small.
And our replies were focused on the generator as that is initially your biggest concern. One of your top priorities in the sound department is dealing with and getting rid of (or at least reducing) any competing noise sources.
Tom Galli
January 15, 2020 at 2:09 amI acknowledge that reducing sound is part of the job.
Hopefully, you will acknowledge that removing all extraneous sound is impossible.
Whatever ambient sound remains, there are times I question if I’m hearing it because it’s in the mix, or because it’s penetrating the isolation value of my headphones and reaching my ears directly. This is what noise-cancelling headphones are specifically designed to combat. So, if I may ask again, why do you consider the use of such a “horrible” idea?
Ty Ford
January 15, 2020 at 2:12 amTom,
That has been asked and answered. Please move on.
Ty Ford
Tom Galli
January 17, 2020 at 11:41 pmThanks for the tip on the headphones! Mine arrived today. They definitely provide more isolation than anything else in my current inventory. They’re certainly comfy enough to wear for 15 minutes; I look forward to trying them on a shoot.
Still, even with 45 dB of isolation, I can hear the clickety-click of my keyboard as I type this, and the laughter of students in the classroom down the hall. Are my ears just more sensitive than average? I find that hard to believe; my youthful love of rock and roll has translated into middle-aged repercussions. My hearing is about average for my age, but I do have tinnitus. Even with hearing loss and tinnitus, these new muffs mark an improvement, not a solution, to the issue of “is it in the mix, or just in my ears?”
I’ll keep looking, but thanks again for the link!
Tom G
Richard Crowley
January 27, 2020 at 6:19 pm[Tom Galli] “”is it in the mix, or just in my ears?””
THAT is the reason to NOT use “noise-cancelling” or any other consumer-scheme technology when doing serious professional work.
Noise-cancelling headphones WILL reduce/remove ambient repetitive noise from what you hear in the headphones. Unfortunately, that INCLUDES reducing/removing the ambient noise that you are RECORDING. So you don’t know (until it is WAY too late and too expensive) that the generator (or the airport or the interstate highway, etc) was a problem that you didn’t hear on location.
That reduces your professional talent to that of a rank amateur who doesn’t even think about ambient noise because they have no experience understanding how microphones work (vs your ear/brain system) when it comes to rejecting ambient noise. If you have tricked yourself into not hearing potential problems, then you can’t deal with them properly. And presumably getting good, clean dialog recording on location is why they are paying you.
As you have surmised, the generator is another self-imposed problem (like using noise-cancelling headphones) which is easy (but not necessarily fast or cheap) to mitigate.
If you have not already encountered it, highly recommend this document which you should read and share with your producer/director/AD, etc.
https://filmsound.org/production-sound/openletter.htm
Recording audio without metering and monitoring is exactly like framing and focusing without looking at the viewfinder. -
Ty Ford
January 27, 2020 at 6:28 pmDear Tom,
You have been told how and why your thoughts will get you in trouble.
I’m not sure we can be of further assistance.
Your tag line, “The difference between theory and reality is that, in theory, there is no difference between theory and reality.” presents an interesting conundrum.
Even in theory, your idea will not work. Please test it before the reality of it bites you it the butt and tarnishes your reputation.
Regards,
Ty Ford
Tom Galli
January 27, 2020 at 7:40 pm[Richard Crowley] “If you have tricked yourself into not hearing potential problems, then you can’t deal with them properly”
Now, that’s an interesting perspective. I’ll have to chew on that.
[Richard Crowley] “Noise-cancelling headphones WILL reduce/remove ambient repetitive noise from what you hear in the headphones. Unfortunately, that INCLUDES reducing/removing the ambient noise that you are RECORDING.”
See, I think a great many people misunderstand how noise cancelling headphones function. It is not like you seem to be describing. They’re designed to eliminate ambient noise, not noise in the signal. For example, when I travel, I have noise cancelling headphones. They do a fantastic job damping the noise of the engines and such, but still play the movie’s soundtrack perfectly. Even, and I need to be explicit here, even if that soundtrack has the noise of jet engines in it! The only noise being cancelled is what’s being picked up by the microphone built into the headphones, which is fed out-of-phase to the driver; no filtration is applied to the incoming signal.
That being said, it seems to me a lot to ask of a single driver to be doing 2 tasks at once, and I suspect this is why people complain about noise cancelling headphones coloring sound, which they most certainly do.
[Richard Crowley] “If you have not already encountered it, highly recommend this document which you should read and share with your producer/director/AD, etc.”
That’s an old favorite! I do love to forward it to directors when I work with them for the first time.
