Activity Forums Apple Final Cut Pro Legacy REVISED QUESTION: FCP5 Drop Frame Error
  • REVISED QUESTION: FCP5 Drop Frame Error
    Posted by Christopher Bagnall on January 12, 2006 at 8:32 pm
    In 4.5, FCP (In LOG & CAPTURE) would save a clip that was terminated due to dropped frames as something like “Filename”AV-1 or some variation there of in the Capture Scratch folder. Is this option still available in FCP5? It was great becasue I didn’t have to recapture the full clip and could keep atleast a partial file. I hope there is a way in the Preferences to change this.
    David Bogie replied 20 years, 8 months ago 2 Members · 1 Reply
  • David Bogie
    January 13, 2006 at 4:17 am
    Nope. but FCP5 will still save clips with those names if the capture is improperly terminated. I find the files are often useless, can’t be opened. But sometimes they work.
    You shouldn’t be dropping frames. That always indicates a deeper issue that really should be corrected.
    bogiesan
