Activity Forums Adobe Audition Reviewing edits
  • Reviewing edits
    Posted by William Wallick on July 3, 2007 at 12:32 am
    So…..I make a selection, delete it and then is there an easy way to review the section surrounding the edit to see how it sounds. Currently I have to find the spot, select either side of it, and then play looped. There must be a faster (read “easier”) way to do this. Thanks.
    Just another video knucklehead…
    Markofcain replied 19 years, 2 months ago 2 Members · 1 Reply
  • Markofcain
    July 3, 2007 at 10:48 am
    What I will do when I need to pull a selection and make sure that I have the preroll and postroll matched perfectly is this:
    (Assuming PC here)
    Right click the play button on the bottom left
    From the context sensitive menu select “Play preroll and postroll and skip selection”
    Click play to see what the files sounds like without the selection.
    Adjust the selection as needed.
    One caveat is that I don’t think it works with the “Play Looped” button.
    HTH
    Mark Cain
    Sarasota, FL USA
