Activity › Forums › Apple OS X › Reverting to earlier operating system 10.4.4 or 10.4.3???
  • Reverting to earlier operating system 10.4.4 or 10.4.3???
    Posted by Rob Sankey on February 28, 2006 at 5:53 pm
    I am currently having problems with 10.4.5 and FCP 5. I am trying to revert to 10.4.4. I tried installing it but I’m getting a message that says my system does not meet the requirements to install 10.4.4
    Any help is greatly appreciated.
    RS
    Rob Sankey replied 20 years, 7 months ago 2 Members · 2 Replies
  • Tony! Hulette
    March 1, 2006 at 12:53 am
    Hi Rob,
    You should be able to startup off of the OS X installation disks that came with your Mac. Choose the “archive and install” option to replace your newer OS with the original one (be sure to check the options to save your files, etc). Once installed you can then update to whatever OS version seems to be working for you (find the various versions on Apple’s website). I would however, check with your capture card manufacturer for any updates or any workarounds for the problems you are having with OS 10.4.5. It could be your plugins, drivers, firmware, etc aren’t up-to-date and that would be a much simpler fix than reinstalling an older version of OS X.
    Tony!
  • Rob Sankey
    March 1, 2006 at 2:21 pm
    Thanks Tony. I’ll give it a try.
    RS
