Activity Forums Adobe After Effects Expressions Revert value to zero once to comp edge
  • Revert value to zero once to comp edge
    Posted by Jim Johnston on March 18, 2018 at 5:33 am
    Hey all. I have a position expression which moves in a certain direction each frame as follows (thanks to Dan Ebberts).
    spd = effect("Slider Control")("Slider");
    angle = effect("Angle Control")("Angle");
    d = spd*(time-inPoint);
    r = degreesToRadians(angle);
    x = d*Math.cos(r);
    y = d*Math.sin(r);
    value + [x,y]
    But I need the x and y values to reset to 0 once they reach a certain threshold (such as the comp width/height).
    I tried adding if(x>100) x=0;
    which works but keeps the value of x at 0 for the remainder..
    Something really simple I suspect but not getting anywhere at the moment!
    Jim Johnston replied 8 years, 5 months ago 1 Member · 1 Reply
  • Jim Johnston
    March 18, 2018 at 6:11 am
    Figured it out. AE doesnt store variables over time apparently. So a modulus function works instead just fine I think
    x = d*Math.cos(r);
    y = d*Math.sin(r);
    value + [x%1280,y%720]
