Activity Forums Apple Final Cut Pro Legacy Revert changes from Soundtrack pro?
  • Revert changes from Soundtrack pro?
    Posted by Mike Wilson on July 2, 2009 at 1:18 am
    Hello,
    I’m working on sound correction for a client. He did some sound work from soundtrack pro but I need to revert the changes back to the original source files. I could do it manually for each clip in final cut but this is a feature film and that process would take too long. Is there a way to select all clips and revert back to the original sound? I am working in FCP and the files were sent to STP from FCP. The audio clips with the “sent” appended replaced the original clips. The original sound files are still somewhere on the hard drive so there may be a way to revert the changes back to the original file.
    Mike
    Mike Wilson replied 17 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
