Reversing/moving split events
Posted by Marcus Lovitt on April 29, 2009 at 5:09 amHi all,
Whenever I’ve made a mistake using Split Event, I’ve always used the undo on the edit menu. Is there a way to remove or move an unnecessary split without having to backup several steps?
Cheers,
Marcus
Edward Troxel replied 17 years, 5 months ago 3 Members · 4 Replies -
Edward Troxel
April 29, 2009 at 12:52 pm -
Terry Esslinger
April 29, 2009 at 3:59 pmTo expand slightly on Edwards answer (not that it really needs it),
You can drag one of the parts of a split event back out to the original length. Remember we are doing ‘non-destructive’ editing. So say you split event A into events A & B. But for some reason you do not want that split anymore. Select event B and delete it, drag the right edge of event A back over where event B was and you are back to where you began. -
Marcus Lovitt
April 29, 2009 at 6:03 pmThanks guys.
What you suggest makes perfect sense. Actually what I was really hoping for is some kind of right-click solution, but nevermind! I’m shooting multicam for the first time and my timeline has splits absolutely everywhere. For the sake of housekeeping, I wanted to remove some of them. Since your solution sounds like a little more work, I won’t worry too much.
Cheers,
Marcus
Edward Troxel
April 30, 2009 at 1:02 pm
